Paper Cut MF error occurred with a bad installer
During the install of Paper Cut this error appeared. I confused because I never installed Paper Cut before and it says that one file already exists on my PC. Any solution for this error ? What is the problem with this program ?
Regards experts,
C:Program FilesPaperCut MFreleasepc-release.exe
An error occurred while trying to rename a file in the destination directory:
MoveFile failed; code 183
Cannot create a file when that file already exists.
Click Retry to try again, Ignore to skip this file (not recommended), or Abort to cancel installation.
