Polmeranz
Posted on - 12/05/2011
Hello Everybody,
I supposed to install the Paperport program in Windows 2000 correctly for editing some of my image files when suddenly one of the image file in the Paperport  program an error appear that file is corrupted. Now, I’m worried if I can retrieve that important file. Please help me. Thanks to all!   Â
Error message:
Corrupted File
Error executing program!
OK
Paperport can’t open my file
The paperport application setup is corrupted and therefore you should not even try using again to install. You will need to search for another installation program so as to use it for the installation. You can use Google search to find the application and then install it. Otherwise you can use alternative download sites to download the application; some of them are the following:
Thompson Locker
