Parallel Internet Security Powered by Kaspersky installation error
While you install equivalent internet security an error came to regard unsuited program.
Indication:
In Windows Virtual machine whenever you attempt to run parallels internet security you are given the error note like this:
Attention! Some incompatible software is
installed on your computer. These applications
cannot be used together with Parallels
Internet Security 2009. In
order to proceed with the installation, remove
these applications.
           OK
Thanking you.
