Parallels Desktop 7 for MAC
Is Parallels DEsktop 7 for MAC safe for use? Anyone who has tried using this? Any issues you have encountered?
Help. Wanted to make sure I won't be risking anything.
Dear Romasfleeman
Practice as much or as modest Windows as you would like. various view modes make it likely for you to customize the level of combination between Mac and Windows without compromise routine. With Parallels Desktop for Mac, you be able to impeccably run both Windows and Mac OS X Lion applications next to with velocity, control and self-assurance. Setting up Parallels Desktop for Mac is easy. carry all your PC programs, papers, photos, song and browser bookmarks to your Mac, then run them all similar to they were complete for your Mac. It’s the most excellent of both worlds on one desktop without rebooting.
Trustfully
Parallels Desktop is a virtual machine. It allows you to create a virtual machine where you can install your Windows operating system. After that, you can then install the Windows application you want to use. It is similar to Oracle VirtualBox on Windows that allows you to create virtual machines and install guest operating systems. Actually, VirtualBox is available on Macintosh.
The Mac version of VirtualBox is probably your great alternative to Parallels Desktop. If you badly needed to install and use a Windows-based software on your Mac, one workaround is to use Parallels. This will allow you to install Windows applications on Macintosh computer. Unfortunately, Parallels is not free software but you can download their free trial.
Head down to the Parallels Desktop page and download the free trial. The trial version can be installed and used for fourteen (14) days for free with full features. For the pricing, visit the Buy Parallels Desktop page for details. A new license costs $79.99 and $49.99 for upgrade.
