joan d vogt
10 points
Posted on - 10/27/2012
Hi guys,
I installed virtuozzo but my installation got corrupted. I tried to uninstall it and it won't fully uninstall either.
Now when I am trying to install virtuozzo container 4.6, I got an error. The screenshot of the error is as follows:
The message states:
Parallels virtuozzo containers 4.6 Installer Information
Error 1720. There is a problem with this windows Installer package. A script required for this install to complete could not be run. Contact your support personnel or package vendor. Custom Action SetFolders_x64 script error -2147024894, WshShell..
OK
Any help in this regard will be highly praised.
Looking forward to your comments.
Regards.
Hi Joan,
This issue might due to unregistered scrrun.dll file. Try following these steps:
From the desktop, click Start, then click Run.
Type "cmd" into the open typing pane.
Then type this line: regsvr32 scrrun.dll (This will register the file scrrun.dll).
Wait for the confirmation message for the registration then that's it.
Hope it'll help.
Hi Joan D Vogt,
If Howell Jessica's solution doesn't work for you. Try this simple and easy steps for your issue.
1. The first thing you need to do is to download the Microsoft Program Install and Uninstall Troubleshooter. And wait until the downloading process finished.
2. When the downloading process completed, open or run the application.
3. And after that just follow the on screen prompts.
That's it. Hope you can solve your issue now.
HelloÂ
Hope that my messgae finds you well.Â
You can try the one of the following:Â
Option No. 1:Â
– Open cmd command.Â
– Type (regsvr32 scrrun.dll) and press enter.Â
– You will receive a message that (dll was successfully registered).Â
If this is do not help then try Option No. 2.Â
Option No. 2:Â
– Check (Windows Installer Errors troubleshooting) from the following URL:Â
Thanks
