Parameter Problem When Opening E-mail
Whenever I’m trying to open an e-mail, the error: Parameter is incorrect always pops-up. What should I do to fix this?
Hello David,
Parameter is incorrect problem appears when you have a missing system file or a broken registry. There are several free softwares you can use to fix this problem quickly. Please visit the following link to download and install the software and then run a scan to fix all the issues you have. After that you will not have this problem anymore.
Hope it helps. Thanks.Â
Hi David,
   This is a database error, if you are opening a mail with an attachment it may not detect the format of the file. You might also opening the email on a 64 bit OS for some components might not still be compatible with such platform. It can be caused by s DLL on your computer that got corrupted. So as a precaution you can run chkdsk on your computer. Depends on what OS you have you can still run the parameter on the command prompt then type CHKDSK <drive letter> :r.
