Parsing error repair tool, need your help on this one
Hi guys, I have am into XML programming. I always run into parsing error. Can you suggest a parsing error repair tool. Need help on this one. Thanks
Hi jeo,
I suggest you Download the Parse Error Repair Tool
(This is a free download – You'll see a new window pop-up for confirmation.)
Pamela Conley
There is also a very good tool that does what you are looking for. It is named XML Marker. If you open the xml file you are working on, it will display all types of errors; invalid tag, missing tag, etc. The graphics is very friendly which clearly pin points where changes are needed. Please have a look at the snapshot I am attaching.Â
Hope it helps.
Best Regards,
Parisi
Firstly, you need to understand why such errors are occurring?
Parsing error means something has gone wrong and we don't understand what is that something?
Firstly look at the report to find out what is error and then edit XML to remove it.
These errors occur due to misconfiguration of system files.
If you have Windows Operating System chances are that computer has registry problems.
Go to this link https://www.fmscout.com/q-3532-Im-getting-XML-Parsing-Errors-help.html
Follow this link for major errors and solutionsÂ
Go here to download tools https://www.altova.com/
Thanks,
