Parsing problem for XML Text Stream
When parsing the provided XML text stream, QuickBooks found an error. While I was trying to make a standard Terms Add Request transaction through the Web Connector, the QuickBooks showed the error. The XML is- [COD true 0 0 0.0]. I’ve reviewed the XML, but couldn’t find anything wrong. There is no exact indication of the error. If anyone can help me to identify the error and a possible solution, his/her effort will be highly appreciated.
