Password for an email sent in outlook
Is it possible to put a password on an Outlook file so that only the recipient will be able to open it?
I know there is some way to protect it. but not sure what
Yes you can send a password encrypted outlook email steps is as follows.
The issue with putting a password for an outlook file is possible. This can be applied to Outlook accounts with POP3 or the HTTP. What type of email account do you have? We need to verify it first it this solution will apply. You can do the following steps, first check the folder that you would like to set up a password for. For POP3 or HTTP accounts just go to Properties and click the folder and type your password. Make sure to use passwords that are strong enough in characters so it would be hard for a person to access your account illegally. Remember your PASSWORDS always.
