Password on Galaxy 2 10.1
I would like to know if there is a way to setup a password on the Galaxy Tab 2.10.1? If so can you point me in the way to get one set up…
Your Samsung Galaxy Tab 2 10.1 P5100 tablet runs on Android 4.0.3 Ice Cream Sandwich originally and can be upgraded to Android 4.1 Jelly Bean. To set the password, you just need to know what specific operating system is running on your device because sometimes it differs. I’m not using Android so I’m not sure if the two versions differ.
Anyway, here’s how you do it on Android Ice Cream Sandwich. On your tablet, go to “System settings”. In “Settings” screen, scroll down and select “Security” then tap “Screen lock” and then “Password”. Enter the password on the next screen then tap “Continue” when you’re done. Enter it again to confirm then tap “OK”. Your password has to be a minimum of four characters to be accepted.
And that’s it. That’s how easy it is. If you want to see how it is done on video, go to How to Set Password on Android ICS Device. For more information about the tablet’s specifications, go to The Price of Samsung Galaxy Tab 2 10.1.
