I am looking for a free or reasonable priced software that I can put on my USB drives to protect the data. I need something that is very secure and can not be hacked. These will have confidential client information so it would be huge if the information was stolen.Â
Password Protect USB Drives Software?
External drive or removable devices with large memory space which makes them extremely easy to keep and carry with you wherever you go. But it is a matter of sorrow that it also makes them easy to lose. To protect the data from these devices, one should use a software which will protect the data. Here is the reliable software name ''Cryptainer Encryption" which allows to password protect all media and data of your devices.
