Patches for Java SE from Oracle
Oracle has released 14 new patches for java SE. Will it be available in the new version of its java SE or can we get only those  patches available online ? What kind of patches they made ?
Hi Nicholas,
About the updated version of java se, the latest version of java contains all of the fixes before that version release including all the bug fixes.
So if you are wondering if you updated to the latest version will you get the patches then I'll quote from the Oracle website "Note that bug fixes are cumulative, that is, bug fixes in previous update versions are included in subsequent update versions"
And to know your current version of java you can open command prompt from start->RUN–>CMD then enter java -version and you should see your current version.
