Path cannot be determined in HostGator Server
I am unable to connect with my HostGator server. I am currently using Transmit. The error I am getting is: “path cannot be determined”. Can anyone help me in this matter?
Which operating system are using, because the absolute path will differ for different operating systems like windows and linux. In case you are using windows, then you will need to make sure that you have declared your path as follows:
c:inetpubvhostsdomain.tldhttpdocs
You should make sure that you have replaced the "domain.tld" with the actual domain name that you are using on that network.
home/cpanel-username/public_html/
In this case too, you will have to make sure that you have replaced the "cpanel-username" with the actual cPanel user name that you are using on that network.
Some of the things you should note are as follows:
Regards
Thompson Locker
