Path required for the ini files
Where can we find the 4 files(saplogon.ini,sapmsg.ini,saproute.ini,sapdoccd.ini) of GUI at OS level (I mean in which directory)? Please help me with the complete path so that I can copy those files according to my requirements.
Answered By 0 points N/A #114294
Hi Talin,
Well there are many ini files in the operating system and they have no exact path to find. The best method to find any thing open derive of operating system and go to search bar and type the name of file. Make sure that you have marked the option for looking in hidden folders also. If that don't work then check your Archives otherwise for ini files follow this path and do what you want.
Go to the derive of windows usually in C
C :> users>user profile>AppData>LocalVirtual Store> then go to the folder of Windows and unhide the hidden files also and look for the ini files which you want.
Hope this will work.
Answered By 590495 points N/A #308581
If you receive a message related to “saplogon.ini” file that says “Entry not found in saplogon.ini,” the problem is with the “saplogon.ini” file itself. If you encounter this error, expect that the file contains invalid blank entries which you need to remove. Open Windows Explorer then navigate to “C:\Windows\saplogon.ini”.
If you need to copy the “sapmsg.ini” file, you can also find it in the same folder as the previous file: “C:\Windows\sapmsg.ini”. The files “saproute.ini” and “sapdoccd.ini” can also be found in “C:\Windows”. If you encounter problems related to these files, please refer to the manual or any accompanying documents for reference regarding the error. You may also visit Installation of SAP Library for more info.
