Pay stub templates: check stub template for Excel
Asked By 35 points N/A Posted on -
Hi.
I want to switch over to paperless pay check for my employees. So can you please tell me about some benefits of the stub templates? Also, I would like to check stub template for Excel. So can you please give me an overview of the same? It would be really helpful. Thanks in advance.
Answered By 40 points N/A #82939
Hi. There are some advantages such as saving time, the transaction being more secure and nobody being able to forge the identity. It is also cost-effective and cannot be stolen and can be traced. It also makes managing the employee’s payroll less complicated. Thus, you need to keep the pay check stub template for Excel handy with the proper format. The pay check template for Excel is present in the .xlt format. In the header, the logo of the company can be placed.
Also, the text related to the employees and the business needs to be filled in the header. Next, there are templates provided such as- In the first table, you need to place the description, rate, no of hours worked, total for some payment types which can be regular, overtime or holiday. The second table consists of deductions that have been made are indicated for the current pay period. There is a column present at the bottom of the template too which indicates the amount deposited in the employee’s bank account for the period. All the totals of the earnings as well as the deductions are calculated automatically. An example can be seen below:
