anonymous
7060 points
Posted on - 03/12/2013
I have been using ArcInfo for geospatial analysis with lots of vector data on Windows XP. I have now upgraded to Windows 7 64 bit OS. Will opening a topography map with zoom and pan on PC Arc Info on Windows 7 be stable? Need feedback guys. Thanks.
Is Pc arc info on Windows 7 stable for topo map?
Hello
Of course, all things which worked in windows xp will work in windows 7 too. If your current version don't work properly in windows 7 then you should visit this site: http://www.esri.com/en/arcgis/products/arcgis-pro/overview
and download new version of your application. In other case if you want to keep your version but you still have problems using your softtware then you can use compatibility mode and set it to windows xp, your problems should be gone. Regads.
