ayannahana
10 points
Posted on - 12/05/2013
Hi there,
I have this XCY X-24X mini PC Atom D2500 Desktop motherboard and wanted to slot in a GPU card which requires integrated mother board, what is the difference between integrated mother board and non integrated mother board, and how does integrated motherboard perform?
PC Atom D2500 Desktop motherboard GPU card upgrading
Hi !
The main difference between the two plates is computing power and thus location: integrated video card (GPU without RAM) is among the motherboard circuitry, dedicated video card is a separate card (GPU RAM plus literally) that can be removed, replaced with another compatible motherboard. (On some models of laptop/PC may be confused with one integrated).
Advantage of integrated video cards such as low cost and does not require installing. The disadvantage is that it cannot be replaced and underperforming compared to a dedicated video card.
A dedicated video card must consider a number of criteria in its selection: the interface model, the cooling system, frequency etc. can all provide good stability of the system.
