PC Companion Error Unable to phone software
I want to update my phone software. For this purpose I used PC Companion.
Whenever I try to update it, I see an installation
error on the screen which says:
As I see it you’re using a Sony phone right? Typical error. For optimum performance it is best advised to get updates for phones whatever latest update there is to improve the stability of software. Running software update can ease typical phone problems. And it is also necessary to make back up’s and save any important data restored, before performing any update. Suggest that you make update with the Update Service instead, download link and carefully follow instructions.
https://support.sonymobile.com/gb/
Notifications
