PC keeps on restarting from boot screen
I had installed Linux. but it keeps on restarting from the boot screen making a Click sound in the motherboard.
Help please?
Help please?
Hi
Dorothy hope the following steps will guide you in fixing of this issue.
Solving this problem is easy, simply enter the correct resolution of our Grub to do this very easily we can use a simple application called StartUp-Manager.
StartUp-Manager is a simple application with which we can configure our Boot Loader Grub easily between the different configurations we can also adjust the resolution.
Install StartUp-Manager is very simple since it is down there, in the default repositories of Ubuntu, is simply a to install Ubuntu Software Center or from a terminal type:
sudo apt-get install startupmanager
Once installed start it (you will be prompted for the password to start it) and on the first tab called Boot Options on Screen we can set the correct resolution, the board also enter the same resolution also on board Advanced -> Resolution of the bootloader menu close and restart.
