Is pc power speed genuine and how much does it cost?
I have come across optimization software PC POWER SPEED. Is it genuine software and does it actually enhance the performance of the computer? I've heard that it is a scam or virus which may in turn reduce the speed of your PC and take hold of documents in the system. Could anybody help me with a piece of advice?
Best Answer by Samuel Charsa
Answered By 0 points N/A #161734
Hello there!
Recently, there are fake PC Power Speed programs scattered around the internet. But I could tell you there is still some legitimate PC Power Speed software. I haven't tried it yet since there is some malicious software that injects trojan and other viruses into your PC.
Try using other programs for speeding up and optimizing your PC. Currently, I am using CCleaner and Tuneup Utilities as my PC Optimization Software.
Hope I helped you.
Answered By 0 points N/A #161735
I'm afraid to tell you, PC power speed isn't genuine. It's a malware and may damage your system eventually. Please refrain from downloading or installing it. If you want to optimize your system there are several ways you can do that.
1. You could download other PC optimizing software. Do a Google search and check the reviews on the software to confirm that it's good optimizing software.
2. You could do some manual optimization of your software. Press f1 on your keyboard (this will help bring the window) and ask about how to optimize your PC there.
I hope you find this information useful
