PC problems finding and analyzing process – method details
I need to use the debug process to find pc errors and  I need to know the process or procedure on how to do that. So far I have learned that with the debug process we can find the faults of process. Should someone know what are the function of debug process kindly let me know.
Alden Clayton
Answered By 0 points N/A #106606
The debug process is used to debug any kind of erroneous operations or malfunctions performed by a piece of program or code. The problems might have occurred with the call stack or the memory addresses. All tracks by the debug process and a jump from the error code is made to debug or find the reason of error. The debug process is responsible to create an error free software. After the testing phase the debug process starts its role. The entire debug statement is compulsorily a matter of great review where programmers rely on. Whenever an error occurs in your machine, an error stack is formed that can be debugged to find the root cause of the error.
Answered By 590495 points N/A #328346
Debug is literally used in programs to find faults in the code. You cannot use it on Windows to find errors in the system. If you want to check your computer for errors, try using PC Tools Performance Toolkit. It supports Windows XP, Windows Vista, Windows 7, and Windows 8.x. I’m not sure if it’ll run on Windows 10 but you can try.
You can use it to check your system for different errors like problems or errors with files, file system, and hard drive. You can also use it to fix errors in the Windows registry and clean leftover entries in the registry left by uninstalled programs. PC Tools also allows you to clean your web browsers’ browsing history and or browsing data including unwanted or junk files, temporary files, and the contents of the Recycle Bin.
