Pc problem is it my os or in my pc.?
Hello Rhauw,
I can solve this problem easily. You just need to go through the process given here- firstly go to 'Start' Menu and right click on the 'My Computer' icon. Then you will 'Properties' and from which you need to click 'Advanced' option.
Now under the 'Performance' option, here you will click 'Settings'. Then you find a list of window so scroll down till you see 'Use Common Tasks in Folder' and select it. Now you need to click 'OK' and finish the process.
Hope you will see the sidebar in your Windows and your problem has been solved. Thank you.
Abiyda
The question is very vague. You did not explain the exact problem of the computer. If your computer is running very slowly and is not sure of what’s causing it, you should check first if your system is infected.
Checking your computer for virus doesn’t mean that it is already infected. It’s just to check if the cause of the slowness is a virus infection.
Update your antivirus then run a full system scan on your entire hard drive. If you can change the setting and include the path “C:System Volume Information” in the scan, it would be better.
If the result didn’t find any hiding virus, the next step is to clean your hard drive for unwanted and or temporary files. You can use any application that handles removal of junk files in the hard drive or simply use Windows’ Disk Cleanup. After the cleanup just defrag the hard drive to improve its performance.
Hello everyone, Thanks a lot to all of you for your kind help. I am really glad to be free from this problem. Since I read this post, I could easily solve the issue.
I applaud both of your strategies because I succeeded! I didn’t know how to do it because I am a normal computer operator, not an advanced operator, just an amateur. So I didn’t think I could solve this issue.
But you guys were really awesome. To Sharath, All your comments and suggestions are very effective and I really appreciated. Thank you guys for helping me to fix my issue.
