That is probably a bug in the operating system. You will need to try performing a system restore and see if it will resolve the issue. If system restore does not yield positive results, you might want to consider doing a reinstallation of the operating system.
When you install Microsoft Windows on a computer, the option to auto-restart is enabled by default. This setting allows the operating system to automatically restart when the system encounters a fatal error. This is normal. The problem can happen any time when you are using the computer and with no particular program. The cause of the problem can be either hardware or software.
In my computer, I experience this problem multiple times a week because I have a problem with the memory. The downside of this Windows feature is that you wouldn’t know what caused the error because it just restarts and no error message is shown. For you to see what caused the error, you can disable this option.
Disable Automatically restart
To disable auto-restart in Windows, click “Start” then right-click “Computer” and select “Properties”. On the next screen, select “Advanced system settings” on the left pane. In “System Properties” screen, in “Advanced” tab, click “Settings” under “Startup and Recovery” section. In “Startup and Recovery” dialog, under “System failure” section, uncheck “Automatically restart” then click “OK” all throughout.
I’m not a tech geek. I don’t keep up with every new gadget launch. I fly a few times a year, watch many movies on my phone, and live in a small apartment where...
With 2025 just around the corner, it is time to start thinking about what tech trends will be coming our way. Tech moves at a rapid pace. Some things may pop up next year...
1....
