PC shut down immediately after cold boot
My PC is 3 years old.
Recently, it shut down immediately after a cold boot. Sometimes it shut down before I could see the Desktop screen.
I have no idea what happened.
Please help me if you could.
Hello dear
I tell them that its some reasons
I hope you can get a response from those possibilities.
During the cold boot, it shut the computer down before you can view the desktop is possible caused by the settings on the computer.
There is a shutdown command that set the time how long the computer shuts off. This enables you to turn off the computer by the use of command line and any additional commands, functionality and features available on windows.
It has a shutdown syntax command to set how long computer reboots.
An example to this is
-t xx
shutdown -r-c —- This shutdown computer within 30 seconds.
shutdown -i —- This open remote shutdown dialog on your Windows.
The settings might set that way, and this has to be check. See the link below for command features.
Notifications
