PC switch-off itself after 1-2second
I have a computer, 6 months old. Last week I had a problem regarding on switching off my computer, so I manually press the power off button or unplugged it. Now my pc switches off itself after a second.
Computer turning off by itself is often caused by overheating. What you can do is to open the computer's case and check if the fans are working. If they are not, try to remove them and clean them, make sure they are free of dust. Then carefuly put them back.
If cleaning the fans inside the computer still causes the computer to turn off without a warning, you need to check the hardware component of your computer. For example, check the memory card, CPU, motherboard and power supply. If your computer continuous to turn off even after checking the hardware component, you can also check if there is a virus so you need an updated virus scanner and check for malware. Â Since you mention your computer is a 6 months old, it is still under warranty, you can bring it back to where you bought it to have a technical support hands on/check the computer.
Computer restarting after 5 or 10 sec. is caused because of RAM , CPU fan .Check the RAM of the computer whether it is working fine or not. remove the RAM and insert it again. clean the CPU fan . if the problem still remains check video adapter of your PC. check that whether you are getting any video adapter related error message.check the power button on the CPU whether your CPU power button is working fine or not.check BIOS setting.
