Adams
20 points
Posted on - 08/05/2011
Good evening friends!
My PC volume disappears automatically.
After few minutes I start my computer my PC volume disappears & clicking the volume icon shows you don't have any sound card installed.
But I have my sound card installed.
I check for the recent driver for my motherboard & installed it but still problem persist.
But after I restart the computer sound comes for a few minutes & then disappears.
I am using windows 7 dual core processor & D945 gcnl motherboard.
Help me out please.
Trevor
PC volume disappears automatically any time of instance
This problem occurs when the automatic update is on. Turn off your automatic update for this device so that the Microsoft Windows 7 does not update for the driver of your hardware when new updates are found. Sometimes drives comes from Microsoft doesn’t work so it is better to use the driver bundled with your hardware.
To fix this, remove your hardware or sound card driver completely and install the driver that comes from the Installation Disc bundled with your hardware. If un-installation of the driver doesn’t work, boot your computer in safe mode then do the un-installation on the safe mode shell, restart the computer then install the driver.
