Pc works slow . To make fast and refresh all time
Hi
My pc is so slow . I have used Avast antivirus but it is not updated. Have any solution to make my pc
fast  . I make it,s refresh all time but after then it show very slow help me why it's occur ? And What
is the reason for that?
Thanks
Best Answer by nathaniel jones
Answered By 0 points N/A #114210
Hi Katrinakaif,
Slow computer performance often caused by expired security software. In your case, you have mention that you have Avast antivirus but it is not updated.
Here are my suggestions;
1. Uninstall Avast Security software.
Go to Start, Control Panel, Add and Remove Programs. Look for Avast Security Software in the list of program installed. Choose Avast Security Software and uninstall.
2. Update Avast Security Software
Open Avast Security Software and look for an option to update the product key.
If your computer still acting very slow, try to do system restore and or re-format your machine. Your computer might have virus infection since your security software is expired.
There you go, these are the steps needs to be done for fast and functioning computer.
Answered By 0 points N/A #114211
Dear Katrinakaif,
Hey dear, at times the system has no virus but antivirus makes it slow. Do these few simple actions hopefully it will help you out.
1. Update your antivirus
2. If possible upgrade the RAM it will help a lot.
3. Remove Unnecessary things from system startup( go to Run, type msconfig, click startup tab, uncheck unnecessary processes)
4.Disable Unnecessary Services (to Run, type msconfig, click Services, uncheck unwanted services)
5. In folder options “Show hidden files and Folders” and see whether there are any files created by themselves in bulk if so remove them all.
Restart system to take effect of changes and now check the speed.
Have a good time.
Answered By 10 points N/A #114212
Hi
Regarding on this issue there is another Techyv post which one also will be helpful for you to remove this issue.
How to refresh a PC properly?
