Pci driver hp for xp pc download after system change
Hi there,
Please tell us about the machine you have. Is it desktop or laptop? What is the model of your computer? If you have the manual of your computer than please read that once more, so that you can understand that do the drivers support the windows XP. Now if the driver does not support windows XP than please contact with the authority from whom you bought this machine. I hope they will have a solution for this. But usually windows vista and XP are almost compatible with one other.
Best regards,
Riley Weaver.
Hello Cathy,
If you want to move PCI driver HP for XP PC after a system change then I would suggest that it’s not a proper way to make a driver. HP system has separate compatibility with drivers so you need to download PCI driver which is fully compatible with Windows XP. You may face compatibility issue so you should download this driver for your Windows Operating System from the following link. It will be a better way to resolve this issue.
https://www.techspot.com/drivers/driver/file/information/15978/
Notifications
