I was using my Windows XP yesterday but when I tried to move files from one location to another, I got an error message. The error message says
"This error message indicates that the PCK/Obsidium virus found in Tera copy software folder."
I tried to look for virus files on the tera copy folder but I found none. How can I find the virus so I could continue with moving my files to another location? If anyone has a solution to this problem sharing it would be a great help. Thank you.
PCK/Obsidium virus files detected but cannot be found
PCK/Obsidium virus is actually type of the Packer and it affects the system setting in the lower level. The PCK/Obsidium virus is detecting common packers useful for malware and then it manipulates its original executable code. Â In this case, there is necessary to remove such kind of virus from the system and restore the code of the file of software. I suggest you to download the Avira antivirus from the official site and then try to install it onto the system. Then download and install the setup files on the system using the official Avira site. After that you need to scan the system completely. This virus is to be easily detected by the Avira and then it repaired that infected files from the system. Then there would be possibility that tera copy software works and you can easily do the copy paste operations.
