PCMCIA Generic Wifi utility Installation
Can somebody help me out with Installing and configuring of PCMCIA Generic WiFi utility for setting up the pc card in my laptop.
My Laptop is a bit older.
Any Suggestions ?
Any Suggestions ?
Hi Sara,
If you can, please follow these simple steps to try to cure your problem.
Now just click OK and you should have working and updated WIFI card in your laptop. Alternatively try to find required drivers through internet. Just write down your WIFI card model like in 4. clause into Google search engine and search for them.
I hope I helped you with your problem.
If you're able to, you should stick to these kind of points in order to treat your complaint.
Firstly, let your own Home windows help detect your own wifi greeting card also to install essential people. At this point click on "Start, " after that "Control Panel. " Select "Classic View" inside the remaining column. Open "System" section and also click on "Hardware" case, after that "Device Manager".
Broaden "Network adapters" simply by simply clicking "+" image. Increase click on your own PCMCIA WIFI greeting card. Note down your own WIFI greeting card name somewhere and also click on this. Click on the "Driver" case, after that decide on "Update driver". Wait for some moments.
Home windows are actually trying to find kept up to date drivers application. At this point simply click ALRIGHT and you ought to have functioning and also kept up to date WIFI greeting card within your notebook. Additionally search for essential people as a result of world-wide-web. Only jot down your own WI-FI greeting card design such as throughout some. Term straight into Search engines search results and also hunt for them.
Hope it will help you.
