nakon jiko
Posted on - 07/10/2013
I cannot find anything and anywhere on google for a help if how to merge documents with pdf architect. I searched several times but to no avail. Is there a User Manual for pdf architect? Why there is not even a simple help out there for this concern? I did manage to find some complicated things about merging using printing and pdf creator form fields but I want pdf architect creator from fields in merging documents. Thanks for any help extended.
Pdf architect creator form fields
Hello Nakon
PDF Architect can merge documents but, it changes the size. Which is not a good thing. You can merge documents, by combining them. You select the documents, and then Combine. It is not hard.
A better software to do this, is Adobe Acrobat. A fully installed version allows you to merge documents easily.
You just Install it, go to Create, and select Merge Files. After that you select the files from your computer, and the program merges them.
I hope you will find this information useful.
Randolph
