PDF conversion problem with DirectPDFExport
Anyone is possible they indicate to me to the changes of the exact configuration that they must be done in UCM 11 g/IBR to turn several image formats (jpeg/bmp/png/tiff) PDF.
You Tried to change the field of the conversion of the formats of the file into the manager of configuration To DirectPDFExport, which the file was converted to PDF, but on having opened the PDF
Its giving the above mentioned error 'file does now begins with' % PDF -".
Did nobody find such errors earlier?
Best Answer by Fraserr Dawn
Answered By 0 points N/A #130298
Hello, James! I think it can be happened to the attack of malware or trojan. In fact, your security system can be damaged or low. Now, you have to uninstall. Of course, use  “Orbit” Uninstaller so that you can enjoy the junk free registry of your PC. After doing this, you can install it perfectly. Before that you must use a licensed antivirus and good PDF converter software. You can get this online. Have a nice day!
Answered By 0 points N/A #199226
Hello James,
Your question has lots of ambiguities but still judging from your post title, i ma sure you are having PDF conversion issues. There are many methods you can use to convert PDF files. Here are some solutions for you that will assist you in your problem:
1. Try to convert the online PDF converter tool by visiting the following websites:
a. PDF converter online
b. PDF online
c. Online documents converter
2. You can also use Adobe reader to convert your PDF files using the online services.
This might help you in your problem.
