When I download PDFs, everytime I open them only lots of squares appear. I tried changing language and all recommended actions in help menu, nothing worked.
PDF Downloads Are Full of Squares
Hi Jericho the problem is very simple and easy to destroy it with an easy solution as many of documents are responsible for restricting the access of the document .
The problem may be with the document you are loading or the application you are using to load the document and hence if it is damaged then it won't load and show the data in the file.
If at all there is necessary to install a few version then you just go to the official website of the data you are downloading and install it if you have already then you just install the updates so that additional features are added.
Now the problem will be definitely resolved without any errors by installing the fresh copy of application and if possible also Operating system.
Thank You.
I experienced similar problems with my PDF viewer too. I also tried everything i know but nothing worked. So i came here for help and was not turned down! Thank u techyv; u r experts have helped me once again. Thanks to everyone, thank u very much
