jcwood
Posted on - 10/31/2011
Hi All,
Is there a PDF Editor that could perform update? Like for example I created a document today and attached it to PDF and by using the PDF Editor I modify the original document on the next day. I want the PDF Editor to update the attachment. Is that possible? I need your suggestion here please! Thanks
PDF Editor With Update Function Any Help!!!
You can try the Adobe Acrobat Professional where you can download from the Adobe website for a free trial of 30 days to test it. It is a different software than the Adobe Acrobat Reader. From the term "Reader" it is to read only purposes only so you really can't edit any PDF file formats using this. The Adobe Acrobat Professional will let you edit or create any PDF files without the ease of using Word and then installing PDF printer just to create PDF files. Editing in this software is pretty simple and easy so you don't need to worry about trying it the first time.
Here is the link:
jcwood
Hello Alber, Thank you for your suggestion. I have downloaded Adobe Acrobat and I was able to update my PDF files.
Thanks Again, you have helped solve my problem.
