I need a step by step procedure to guide me on how to create & convert my image files saved in PDF form to JPEG through the Joomla platform. The files will be posted online so through Joomla file thumbnail gallery, they will be easier to display and download as well as manage & edit easily.
PDF to JPEG gallery conversions using Joomla?
Hi
You wanted a download for pdf to jpeg. You mentioned that the conversion should be in joomla platform. Try the steps below:
1. Download the software and register with proper process:
https://www.freedownloadmanager.org/download/PDF_To_Image_Creator_67805_p/free.htm
2. Install the software in the pc.
3. Put your see in the input path.
4. Show an output path and click convert.
5. Check the output folder for converted jpeg.
Hope these helped you.
Hi Laura,
    First you go to your joomla image gallery and save all images of pdf .when all images download so you can change pdf images change to jpeg there are many ways first you can download pdf changer into jpeg software, or change by HTML slicing, or if you have these images in illustrator you can save as jpeg easily. When all images convert into jpeg go to joomla images gallery and upload it.
Thanks
Raun Nelosn
