ann tanner
20 points
Posted on - 10/18/2013
Hello All,
I was having Adobe Professional Pro in home system, which helped me to convert PDF to MS Word with quality. But my office system dosin't have Adobe Professional Pro, but I would like to know whether there is any PDF to MS Word docx converter that will work with the help of Internet.
Please suggest & Help,
Ann Tanner
Saving .docx files to pdf is usually not difficult and does not cause quality problems. It is indeed more complicated with the opposite process. There is a variety of online converters, so take your pick (but note that editing options for the former pdf-file as a word file might be somewhat limited):
Here https://www.zamzar.com/conversion/document/pdf-to-docx.php is one example of a free online converter for different file types.
Here https://www.pdfonline.com/pdf-to-word-converter/ is one specifically for pdf to word.
This one https://convertonlinefree.com/ also allows to convert whole folders.
Hi Ann
Yes there is not just PDF to MS but to all type of files, PDF to Microsoft Word, PowerPoint, Excel, and html and vise versa. It can also convert images, music, video, and EBook format. It is a useful converter that can convert many types of file formats.
This is the Zamzar free online converter. Just follow the four simple steps and you have your files converted.
Step 1. Choose a file you want to be converted.
Step 2. Choose what format you want it to be converted.
Step 3. Enter your email address to receive the converted files.
Step 4. Click convert.![](https://www.techyv.com/sites/default/filesx/users/Anica%20Macri/Images/Zamzar-PDF-to-word-file-converter.jpg)
