Is there any PDF to PDF compressor Mb to kb online provider, which will help me to reduce the size of the PDF without having any quality issue, as I need to reduce the size of print version PDF, so that it's used as online material.
Earlier I do it using Adobe Professional, my current does not have that facility, please provide an online providers web address.
PDF to PDF compressor mb to kb online provider
Hi Alland!
Fortunately, there are a lot of online compressors that can help you reduce the size of your PDF document.
The Very PDF Free Compressor lets you choose what exactly do you want to compress, like the color images, gray scale images or monochrome images.
The Neevia converter, for a change, gives you the advantage of making the PDF compatible with different versions of Acrobat Reader, and also you can set the image compression at various values.
On a change, The Small PDF compressor is also good, but you don't have so many options to choose from. Still, it reduces your document to 144 dpi, an easier to transfer value. All of them are free to use, and I hope it will meet your needs.Â
Hope it was helpful!
