PDF read only file to Microsoft Excel or Word
Hey ,Joan D Vogt
Firstly you have to need a converter . The converter name is PDF to Microsoft Excel or Microsoft Word. After finding this converter ,you submit your file and click it on convert place.
You can get easily by searching on Goggle . If you want to convert it freely , you will need a mail address.
On the other hand you can buy it through Internet or outlet . then you setup it on your PC.
To convert PDF file to Word you should use some program which is for recognition of text from scented papers. Those programs take PDF files, make big bmp pictures and than recognize the text, pictures, tables, they can recognize everything.
Programs that can help you are finereaders.
Examples:
ABBYY fine reader professional – it can read letters from pictures (all formats possible) and from PDF files also and convert it in Word.
Other program is Solid Converter PDF v3.0.
PDF to Word, characteristics: simplicity;very fast and demanding no installation;transparency in the sense that it is very clear where to put what.
Actually, converting PDF to MS Excel document or MS Word document is simple, due to the fact that there are lots of Free converters available in the Internet that could do such tasks. All you have to do is to download those Free converters and install it to your personal computer / laptop. On the other hand, there are also online converters that are proven effective by many users, one of those converters is Zamzar (http://www.zamzar.com/) . Below are the steps on how Zamzar works:
Hope this helps!Â
~Sjamora
