Greetings everyone! I have been creating PDF files and my friend suggested me this pdfdesk easy PDF creator 2 02. I would like to know if this pdfdesk easy PDF creator is reliable for creating PDF's and what is its advantages and disadvantages compared to the other PDF creator?
Pdfdesk easy PDF creator 2 02
Hi! Easy PDF Creator version 2.02 allows you to create a high quality PFD file. Compare to others, this Easy PDF Creator is easy to use and has a low price. This software will allow you to make a PDF that supports a password protection, resolution, 40 bit and 128 bit encryption, font embedding, tables, formulas, document damage control and many more. It has also a plug-in that will allow you to convert your PDF files to other text script such as RTF, HTML and text formats that will preserve all the graphics and layouts of the original PDF files. You don't need to download and install this kind of plug-ins to your Easy PDF Creator because it is included in the package.
This software supports Windows 2008, 7, Vista, XP, 2003, and 2000
