Leon M Wolf
Posted on - 08/27/2014
I just installed PeaZip on my PC with Windows XP SP2 and the program is fully compatible with my OS. I have this error after I have installed PeaZip when I try to open the program. Can anyone help me please to fix this error ?
Regards experts !
PeaZip
List index exceeds bounds (0).
Press OK to ignore and risk data corruption.
Press Cancel to kill the program.
OK
Cancel
PeaZip cannot be opened after installation
It’s not clear if the problem appears when starting the program or when you are compressing files. But whatever reason, check if you are using the latest version. If not and you are still using an older version then you should upgrade to the latest version since the program is free. Download and install PeaZip 5.4.1. It supports all versions of Microsoft Windows.
Try it again after upgrading the file archiver and then see if it works. If the error appears when you are compressing some files then check the settings you selected for the archive as well as the file format of the archive. It is possible that the file format or the archive format is not compatible with the settings.
If the problem continues, try using other file archiver like for example WinRAR. Download the latest version, WinRAR 5.11.
Hello Timothy,
The best way of getting the Pea Zip program to open is to install the peazip execute repair tool. The application is made to diagnose a variety of issues with Windows. The Pea Zip repair tool will also enhance your system's production. Go to exelist.net/registry/peazip-exe.php.
