How to recover the files deleted from pen drive. I had taken no backup but deleted it a absent mind and now I am regretting. I have read many posts online but very scared to try any of them because this might make the recovery option worse. Had anybody earlier extracted data from pen drive or hard disk after deleting it permanently? I also visited a few service centers, they said they can try but it is not guaranteed to extract the data, they might be able to extract some files but the charge they are quoting is too much. It costs my one semester fees. Please help
Pen drive data deleted accidentally How to recover
The possibility of recovering the file is there but the correctness or getting the file error-free is not. Download PC Tools Performance Toolkit then follow the instructions to download and unpack and then install it. Once installed, start PC Tools then go to “Recovery” tab and click “Recover Lost Files.”
PC Tools recover deleted files
On the next screen, in “Scan type,” select between the three options: Quick Scan, Deep Scan, and Physical Scan. In “Scan the selected drives,” select only the drive letter of your pen drive or USB flash drive for a much quicker scanning. By default, all drives are selected. In “Scan by file type,” refine your option by selecting the file types you want to search.
PC Tools set scanning parameters
When you are finished setting the scanning parameters, click “Start Scan” to begin the scanning of the drive. The best way to recover a deleted file is not to touch the drive after the file got deleted. Don’t make any changes to the drive like don’t copy, rename, move, or delete files or folders on the affected drive.
1....
