Pendrive 4gb to 8gb Software
Would you tell me please how can i get "pendrive convert 4gb to 8gb software" and how can i develop it ?
Hi!
Pendrive Converter is an easy to use software that converts DVDs to iPhone, iPhone DVD Converter etc.
Here’s a site where you can download Pendrive. There’s Pendrive Reminder 1.8.0.1, Pendrive Recovery Mac 4.0.1.6 and a lot more. Browse through the site to find the software you are looking for. Some are freeware, some are not.
http://www.freedownloadmanager.org/download/how-to-convert-4gb-pendrive-to-8gb-4338436.html
And here’s another site:
http://soft.udm4.com/downloading/convert_4gb_to_8gb_trick/
Hope I have helped you. Enjoy!
Hey  Mohammed Fathy,
Well, you want to convert your 4 GB pendrive to 8 GB pendrive, certainly increasing its capacity. But I doubt you would be able to do that. Sorry my friend the only way to do this would be buying a new 8 GB pendrive.
Regards Ian M Tyner.
