Pentoo 2012 beta release download
Where can I download the new penetration testing tool which is available as a beta version. This I wanted use for the daily basis and wanted to download in as early as possible.
Hello William,
The new penetration testing tool is available for download on many sites, including the Pentoo site: www.pento.ch. If you prefer downloading from other sites too, you will need to try the following:
You can also check other sites like CNET downloads and MajorGeeks. For more information about this beta release, you can check out sites like https://cyberarms.wordpress.com/2012/07/31/pentoo-2012-a-penetration-testers-distro-of-gentoo-linux/Â as well as https://distrowatch.com/?newsid=07546
There are other sites apart from the ones provided above that will offer the penetration testing tool for download, but in case you come across such sites you will first of all need to make sure that the applications they are offering are genuine so that you do not end up getting an application that may crush your system.
Carl
Pentoo is a Live USB and Live CD penetration tool. It is designed for security assessment and penetration testing based on Gentoo Linux. It is available in 32-bit and 64-bit installable Live CD. It is also available as an overlay for an existing Gentoo installation. It is basically a Gentoo install with plenty of customized tools, customized kernel, and more.
It features packet injection patched Wi-Fi drivers, GPGPU cracking software, and plenty more tools for penetration testing and security evaluation. The following are some of its features:
Tools are installed with versioned ebuilds as well as open-ended ebuilds making it possible to get the latest subversions and still have installs tracked according to package management. It includes the following tool categories: Analyzer, Bluetooth, Cracker, Database, Development, Exploit, Footprint, Forensics, Forging, Fuzzers, Misc, MitM, Pentoo, Proxy, RCE, Scanner, SIP-VoIP, and Wireless. If you want to try it, go to Pentoo Download.
