PERC Controllers has beeping sounds
The 5 controllers of PERC (Dell PowerEdge RAID Controller) are continuously beeping.
How to solve this issue?
Hi Stephanie Gray,
You can hear these beeping noises if you are using a PERC (Dell PowerEdge RAID Controller) 5E or PERC (Dell PowerEdge RAID Controller) 6E, though the internal controller doesn't make any noise.
You can try the following two options as a solution for this issue:
Option 1:
Step A: Choose the controller in the Open Manager which you will find on the left side
Step B: Right click the icon for Information Configuration
Step C: Mark the controller task and disable the alert
Option 2:
Step A: Go to Properties
Step B: Right click on Adapter and select SYB Menu
Step C: It will open Alarm Control, choose on Silence
Check that all the system is configured correctly.
You need to check what kind of sound is coming from the controllers also check that what kind of error message it is.
Then you will be able to solve the problem. first of all remove all the hardware and then configure it one by one then check where the problem is and you will be able to solve your problem.
As you will configure them one by one then check that where the problem is and then you can replace or repair it also.
It is easy and safe method. If you have not service your product then you need to service it for it long use.
It will solve your problem.
