Perfect Uninstaller 5 for uninstalling programs & applications
20 points
Posted on - 04/01/2013
I was suggested by my boss, to use Perfect Uninstaller 5 for uninstalling unwanted programs and applications from the PC. Usually I use "Uninstall or change a Program" option in the control panel to do the uninstalling, then why should I use additional application called "Perfect Uninstaller". Is there any special features for that, please guide me.
