elicole
Posted on - 03/06/2012
Hello guys,
Please help me find a solution to my problem. I downloaded and installed the PerfectJob Software trial version. When I start the software, it shows a flash screen showing “Version 1.0.4.96…. Updating Database Schema…” and then gives me the error message written here below.
The headline is: "905 Fatal Error "
The message itself says: "5074 The Index 'Unique_Username' is dependent on column 'Username'. ALTER TABLE COLIMN Username failed because one or more objects access this column. Command: /****** Version: 1.0.1.13 ******/ ALTER TABLE [dbo]. [User} ALTER COLUMN Username vachar (255) null; "
Have you seen this kind of error message before? What does this mean?
Help me out please.
Thank you.
PerfectJob Software 905 Fatal Error
I’m not sure if you have an incompatibility issue here because this application does not require high computer specifications in order for it to be installed on a computer. To install PerfectJob software on your computer, your machine should be running on these Windows versions: Microsoft Windows XP Service Pack 2 32-bit and 64-bit, Windows Vista 32-bit and 64-bit, and Windows 7 32-bit and 64-bit. You must have at least 512 MB RAM installed on the CPU. This application only requires 25 MB available hard disk space.
If you encounter a fatal error upon opening the application, try uninstalling and then reinstalling PerfectJob Software to fix any corrupted files on the installation of the application and to restore its settings back to default including some of the settings that you might have customized.
If it still does not work, try downloading the installer again at https://www.hugedomains.com/domain_profile.cfm?d=perfectjobsoftware&e=com and then install it on your computer.
