Performance we can expect from the Dragon Naturally Speaking
What type of speed and accuracy can we expect if we use the Dragon Naturally Speaking voice recognition software?
Many users are astounded by the incredible precision offered by Dragon. In fact, Dragon NaturallySpeaking delivers a rate near 99% after installation. And the more you use, its accuracy increases more! And thanks to a faster memory content of your documents, your dictation, and corrections that you make the keyboard or voice, the number of corrections to fall hard with use.
For the transcription speed, if you use Dragon NaturallySpeaking , you can you can do you job up to 3 times faster than if you are using a keyboard.
Moreover, in case of problems in audio quality, Dragon NaturallySpeaking 11 tells you immediately and offer advice to correct the situation.
Thank you
There are users who are having a hard time installing the software on their own computer. They just know that they need to use the application but were not aware if their own computers are still compatible to run it. There are also users who have compatible systems but still encounter a problem in the installation. Like for example, if during the installation the Setup Wizard failed to install the software because it was unable to access a certain “ENU.cab” file, this means that the file is either corrupted or is actually missing.
If this is the case and you just downloaded the software, simply download it again but maybe from a reputable source this time since the first website already come up with a faulty installer. And for those users who don’t know if their computers are compatible to run the version 10 of Dragon NaturallySpeaking, here are several of the specifications. For the Dragon NaturallySpeaking 10, you must have a system that runs at least on Pentium 4 processor or AMD Athlon 64 with speed of at least 1 GHz. It supports Windows Server 2000, Windows Server 2003, Windows 2000 Service Pack 4 or higher, Windows XP Service Pack 2 or Service Pack 3 32-bit, Windows Vista Service Pack 1 32-bit or 64-bit, and Windows 7 32-bit or 64-bit.
Thank you friends, I appreciate all the helpful tips you suggested. Dragon Speech Recognition Software works very well here it makes it easier for me to use a computer. The software can capture my thoughts and ideas quickly and easily. It helps me get more work done faster. I would like to know more about the performance of the Dragon Naturally Speaking and its awesome features. Moreover, after reading through your solution I have learnt useful information and instructions that determine the speed and accuracy I can apply while using this software. In addition, I no longer experience difficult installation problems. As I said, it makes work easier because I can now determine what type of system we need,. Thank you guys! As well as TECHYV.
