Performing A Fix To Winword Exe 0xc0000005
I’m getting this winword exe 0xc0000005 after trying to open the word version (2013). I want it to be integrated quickly. Can someone help me?
Disable your hardware acceleration
That solved my problem!
If you keep getting this error with Microsoft Office Word, check the system requirements and verify that your computer meets those requirements. Microsoft Office 2013 supports Windows 7 Service Pack 1, Windows 8.x, and Windows 10 including Windows Server 2008 R2, Windows Server 2012, Windows Server 2012 R2, and Windows Server 2016.
It requires 1 GHz or faster processor with SSE2 support, 1 GB RAM for 32-bit and 2 GB for 64-bit, 3 GB free space, 1024 x 768 minimum screen resolution, and Microsoft DirectX 10-compatible video card. If you receive this error for the first time, just restart the computer and try again. It could be just a random error.
If this doesn’t work, try to uninstall and reinstall this feature if you have the entire Microsoft Office installed. Click “Start,” “Control Panel,” and then “Add or Remove Programs” or “Programs and Features.” Select Microsoft Office then click “Change.” On the next screen, make sure “Add or Remove Features” is selected then click “Continue.”
On the next screen, select “Microsoft Word” then set the option next to it to “Not Available” then click “Continue.” Follow the instructions. Restart your computer when you are prompted. Once Office Word is removed, open your web browser and download the free version of CCleaner and install. Once installed, start CCleaner and clean your system.
Restart your computer then repeat the same steps to access the installation options of Microsoft Office. Install Microsoft Office Word back by setting its option to “Run from My Computer” or “Run all from My Computer.” Click “Continue” and follow the instructions. See if this works.
