carl gock
30 points
Posted on - 07/17/2019
My system gave me an error of api32 dll missing so I had decided to perform api32 dll download. But will downloading this file solve the problem. How can I make sure that I am actually downloading the correct version or not?
Performing Api32 Dll Download
Yes, downloading the file required by you will solve this error however, that a nice question about how to be safe on the choice of your file download. First, browse the website descriptions and choose the right file for your program. Focus on whether it is a 64-bit or 32-bit file. For 64-bit programs, use 64-bit files, if they are listed above.
It is better to choose those DLL files whose language matches if possible to the language of your program. We also tend to suggest downloading the latest versions of the DLL files to keep the application up-to-date. Other than this, you can download the file from any website of your choice but don’t forget to save this file in the Windows system directory.
