Performing Prism3d Engine Fix
My game shows an error that says prism3d engine has stopped working. I tried to solve it a lot but nothing works. Can somebody help me in performing prism 3d engine fix?
If there are no update patches and the program was running on one of the previous operating systems, I recommend that you start the program in compatibility mode.
1. Right-click on the Setup icon of the program.
2.Click Properties
3. Click on the compatibility tab.
4. In the Compatibility area, check the “Run this program in compatibility mode for:” option.
5.Select the Windows scene in the tank
6. In the permission level “Run programs as administrator”, check the box. 7. Click on “Apply”.
8. Click “OK”
